[mapguide-users] 2.2 RC1 64 bit - unable to build
Amrinder Ganda aganda at i-opentech.com
Wed Oct 27 15:30:22 EDT 2010
Ok. This is what I am doing for development of .NET apps which you might
want to check. This might not be the best solution, and probably is not in
my opinion.
I have setup the dotnetviewersample (samples which you can download from MG
website and follow the setup instructions for IIS) as an application under
IIS. Path like - Default Web Site > mapguide > dotnetviewersample. Then I
open this application from within VS like File > Open Website > Local IIS.
You should now be able to debug your application. Please note, you need to
run VS in admin mode on Windows 7 to open websites like this from IIS. Also,
this way you will use IIS as your dev server rather than ASP.NET dev server
that comes with VS.
Hope this helps.
Thanks,
Amrinder Ganda
GIS / Web Developer
Transforming IT Decisions Into Competitive Advantage!
E: aganda at i-opentech.com
O: 604-746-3682
W: www.i-opentech.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Wednesday, October 27, 2010 11:40 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] 2.2 RC1 64 bit - unable to build
No they do not, Same environment as you though.  I still receive the
compiler error when opening a webform referencing the MapGuideDotNetApi
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444 x 260
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Amrinder Ganda
Sent: Wednesday, October 27, 2010 2:21 PM
To: 'MapGuide Users Mail List'
Does your project runs fine when you choose "yes" in the VS build errors
message box?
I still have this issue whenever I am debugging my .NET apps, but our
projects work well - atleast till now :)
Dev environment - Windows 7 64-bit, IIS7.5, MG2.2 64-bit RC1, VS 2010
Thanks,
Amrinder Ganda
GIS / Web Developer
O: 604-746-3682
Sent: Wednesday, October 27, 2010 10:51 AM
Subject: [mapguide-users] 2.2 RC1 64 bit - unable to build
Trying to Build 2.2 RC1 64 bit Project in VS 2010 and keep getting
Could not load file or assembly 'MapGuideDotNetApi' or one of its
dependencies. An attempt was made to load a program with an incorrect
format.   Seems like that would mean these are 32 bit dlls then?  I
downloaded the 64 bit installer.  Anyone else successful with a .net
project?
Thanks,
Brian  Berdel
www.mcmtrans.com
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the
printed copies (also known as 'hard copies') that are signed and sealed by
the Engineer and/or Land Surveyor. Files in electronic formats, or other
types of information furnished by the Engineer and/or Land Surveyor to you
such as text, data or graphics are for your convenience only. Any
conclusions or information obtained or derived from such electronic files
will be at the user's sole risk. When transferring documents in electronic
formats, the Engineer and/or Land Surveyor makes no representation as to
long-term compatibility, usability, or readability of the documents
resulting from the use of software application packages, operating systems
or computer hardware differing from those used by McMahon Associates, Inc.
at the beginning of the project.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1152 / Virus Database: 424/3222 - Release Date: 10/27/10
