[mapguide-users] Fusion 2.2 RC1
Berdel, Brian
brian.berdel at mcmtrans.com
Thu Oct 28 14:36:24 EDT 2010
Thanks, I am able to get the Samples to work correctly as well.
Brian
Brian,
The standard template works for me with the most recent MGOS2.2
release. I am seeing an error with the Google layer now that I will fix.
Mike
On 10/28/2010 9:12 AM, Berdel, Brian wrote:
> I can add tickets for this, but before I do I wanted to check if anyone else has tested fusion successfully with 2.2 RC1. I am able to bring my map up with the install version but I immediately notice that the google base layer is on the other side of the world and the selection tool is not functioning properly. I also tried the SVN version and there is an immediate error of console is undefined.
> Thx
> Brian
> Important notice to recipients:
> Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
madair at dmsolutions.ca
http://www.dmsolutions.ca
http://research.dmsolutions.ca
