[mapguide-users] URL Activated For Feature
Mark Hedges
hedgesm at cityofnorthlasvegas.com
Thu Sep 16 18:33:19 EDT 2010
Hi All,
I have a Directory called PDF. It is located at C:\PDF on my hard drive.
This directory contains approximately 5,000 differently named PDF files.
Using IIS I have set up a Virtual Directory called "Valve Sketch Boundary".
The path for this directory is C:\PDF. In MG Studio I have a layer created
and in the URL Activated For Feature I have the following:
'http://localhost/Valve Sketch Boundary/1.pdf' (The 1.pdf is the name of the
first of approximately 5,000 other PDF files. Using MGOS I press Ctrl +
select and the PDF file opens fine. My issue is that I don't want to open
the 1.pdf file everytime. I want it to fire off the correct pdf file. I
have spent all afternoon searching this site and online and can't figure
this out.
Any Help Would Be Greatly Appreciated.
Mark
View this message in context: http://osgeo-org.1803224.n2.nabble.com/URL-Activated-For-Feature-tp5540681p5540681.html
