[mapguide-users] Point Fill Patterns
Steve G
steve.golden at morganhill.ca.gov
Wed Sep 22 19:40:17 EDT 2010
I am able to use the fill patterns with area/polygon features, however, when
I try to use fill patterns on point features it doesn't work. It will only
display a solid fill or nothing. I am using Maestro and selecting "Square"
as the symbol. Any fill pattern that I choose results in the same thing. I
have also tried selecting different schema versions (1.1, 1.2, 1.3). Below
is a copy of a portion of the xml file where the shape and fill is called
out.
Anyone run across this problem? Any suggestions?
<PointSymbolization2D>
<Mark>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
<SizeX>10</SizeX>
<SizeY>10</SizeY>
<Rotation>0</Rotation>
<Shape>Square</Shape>
<Fill>
<FillPattern>Shapefill30</FillPattern>
<ForegroundColor>ff000000</ForegroundColor>
<BackgroundColor>ffffffff</BackgroundColor>
</Fill>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Point-Fill-Patterns-tp5561249p5561249.html
