[mapguide-users] Re: Sign MapGuideDotNetApi.dll from Mapguide server 2011 to use with MaestroAPI.
Birgir bgu at geograf.dk
Mon Sep 27 04:12:48 EDT 2010
I was able to sign the five dll's that the MapguideDotNetApi.dll refers to,
but when I try to open the connection i get an warning and an error.
Im not sure if it makes any sense, but do I need or is it possible to sign
the mapguidedotnetapi.dll even though it only type forwards to other dlls?
I thought perhaps that I would need a newer Maestro release to run with
mg2011?  Currently I am running MapGuide Maestro version 2.0.0.4650.
In regards to the warning then the bin folder contains all the dlls
required, to the best of my knowledge.
Not sure about the error, it might be because the mapguidedotnetapi.dll
isn't signed?
I get the following warning:
Failed to create a native component! - check that webconfig.ini is valid and
that the WebGIS "bin" folder contains the Mapguide dll's
Error: Could not load file or assembly 'OSGeo.MapGuide.PlatformBase,
Version=2.2.0.5305, Culture=neutral, PublicKeyToken=null' or one of its
dependencies. The located assembly's manifest definition does not match the
assembly reference. (Exception from HRESULT: 0x80131040)
Source: mscorlib
Stack trace:    at System.RuntimeTypeHandle._GetTypeByName(String name,
Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly,
StackCrawlMark& stackMark, Boolean loadTypeFromPartialName)
   at System.RuntimeTypeHandle.GetTypeByName(String name, Boolean
throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark&
stackMark)
   at System.RuntimeType.PrivateGetType(String typeName, Boolean
stackMark)
   at System.Type.GetType(String typeName)
   at MapGuide2007Wrapper.MapGuideInterface.InitializeWebTier(String
configFile)
and this error:
Page conflicthandler.aspx failed to load, referer:
http://geomgep/sagsbehandlerwebgis2011/extkort.aspx?id=SAGSBEHANDLERWEBGIS2011
Error: Could not load file or assembly 'MapGuideDotNetApi,
Version=2.0.0.2308, Culture=neutral, PublicKeyToken=f526c48929fda856' or one
of its dependencies. The located assembly's manifest definition does not
match the assembly reference. (Exception from HRESULT: 0x80131040)
Source: MapGuide2007Wrapper
Stack trace:    at
MapGuide2007Wrapper.NativeMethods.CreateFeatureSource(String sessionID,
String projection, String projwkt, String resid, Dictionary`2 columns)
   at MapGuide2007Wrapper.NativeMethods.CreateFeatureSource(String
sessionID, String projection, String projwkt, String resid)
   at MapGuide2007Wrapper.MapGuideInterface.CreateMarkupLayer(Session sh,
String template_layerid, String newlayerid, String newfeaturesourceid,
String layername, String coordCode, String legend, Boolean showInLegend,
Boolean selectable, Dictionary`2 columns)
Boolean selectable)
   at GEOGRAFWebGIS.conflicthandler.ActionsMapGuide2007(WebSite thissite,
String tool)
   at GEOGRAFWebGIS.conflicthandler.Page_Load(Object sender, EventArgs e)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Sign-MapGuideDotNetApi-dll-from-Mapguide-server-2011-to-use-with-MaestroAPI-tp5558959p5573921.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100927/5ee06fd8/attachment.html
