[mapguide-users] Re: Standard Viewer Measure Tool Miles to Feet
Steve G
steve.golden at morganhill.ca.gov
Tue Sep 28 17:28:23 EDT 2010
I first did this in MGOS 2.0 and documented my changes. You just need to
follow the correct path/file names if you are using 2.1 or 2.2 which should
have installed to C:\Program Files\OSGeo
To change the measure tool to measure in feet:
1. Open C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewerphp\measure.php in
text editor. Change the conversion factor to convert from meters to feet
instead of meters to miles:
$distance *= 3.2808399; //get feet
2. In the C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\viewerfiles\measureui.templ
file, modify the show units function to set the units var to "Feet".
Line 115 var units = GetParent().GetMapFrame().IsEnglishUnits()?
"__#MILES__#": "__#KILOMETERS#__";
To:
Line 115 var units = GetParent().GetMapFrame().IsEnglishUnits()? "Feet":
"__#KILOMETERS#__";
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Standard-Viewer-Measure-Tool-Miles-to-Feet-tp1818557p5581332.html
