[mapguide-users] Re: Mapguide-Apache URL rewrite
ggdm
giudim86 at libero.it
Sat Apr 2 08:01:05 EDT 2011
Tried over and over again but still not satisfied.
as previously said even single iFrame breaks search widget (and maybe
something else), in the sense that I can search, find results but link to
the feature in the map doesn't work.
Still looking at Apache Rewrite Rules.
Some progress are reported here:
RewriteRule ^gis
/mapguide/fusion/template/mapguide/slate/index.html?ApplicationDefinition=Library://SomeFolder/SomeFlexibleLayout.ApplicationDefinition
RewriteRule ^(jxtheme|icons)\.css$
/mapguide/fusion/template/mapguide/slate/$1.css [L]
RewriteRule ^images/(.*)$ /mapguide/fusion/template/mapguide/slate/images/$1
[L]
RewriteRule ^(.*)$ /mapguide/fusion/$1
This way I can correctly load .css in the template folder and fusionSF
library. I could even move the overviewMap all over but not much else
Looking in Fusion-SF.js I found a constant named "fusionURL" that could
potentially solve it all.
So I tried the usual:
http://www.somesite.com/mapguide/fusion/template/mapguide/slate/index.html?ApplicationDefinition=Library://SomeFolder/SomeFlexibleLayout.ApplicationDefinition
with the addition of:
&fusionURL=somethingstrangehere
to see if it breaks the usual loading of the page. But it runs fine so I
suppose this constant remained the same!
More help appreciated!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapguide-Apache-URL-rewrite-tp6228837p6233712.html
