[mapguide-users] Re: google map integrated but need to on off the
legend to put layer on original location
bjoseph82
brendajoseph82 at gmail.com
Mon Apr 4 03:08:18 EDT 2011
Jackie, now i'm using Mapguide maestro 3.0, so now if i want to edit my
ApplicationDefinition i should do it in MapGuide Maestro using XML editor is
it? so now where should i put my google API Key?
On Mon, Apr 4, 2011 at 2:26 PM, Jackie Ng [via OSGeo.org] <
ml-node+6237408-2063986561-325897 at n2.nabble.com> wrote:
> Hmm,
> With MapGuide Open Source 2.2, this commercial layer stuff is built-in to
> fusion. You shouldn't need to modify the index.html in any way. You only
> need to modify the ApplicationDefinition
> Note that with MapGuide Maestro 3.0 (currently beta 2), the fusion editor
> has an easy UI to enable Google Maps. So if possible, you should use this
> version of Maestro.
> In summary:
> 1. Undo any changes you have made to your template index.html and related
> files
> 2. Edit your ApplicationDefinition with Maestro 3.0, enabling Google Maps
> is simply a case of ticking the Google Maps layers you want and plugging in
> the API key.
> 3. Make sure your Map Definition is in the Popular Visualisation Mercator
> coordinate system (cs code: WGS84.PseudoMercator, epsg: 3857), and that the
> extents are re-projected to this CS as well.
> - Jackie
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/google-map-integrated-but-need-to-on-off-the-legend-to-put-layer-on-original-location-tp6237144p6237408.html
> To unsubscribe from google map integrated but need to on off the legend
> to put layer on original location, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6237144&code=YnJlbmRham9zZXBoODJAZ21haWwuY29tfDYyMzcxNDR8LTE0NzU2MDM5NTY=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/google-map-integrated-but-need-to-on-off-the-legend-to-put-layer-on-original-location-tp6237144p6237470.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110404/37c8e16d/attachment.html
