[mapguide-users] RE: Problems with print layout in DWFviewer
Ward Kilby wkilby at telus.net
Sun Apr 10 01:52:36 EDT 2011
Hi Jackie,
Found it! Thanks for the hint.
  _____
[mailto:ml-node+6258267-411200249-10250 at n2.nabble.com]
Sent: April-09-11 10:08 PM
To: Ward Kilby
Subject: Re: Problems with print layout in DWFviewer
The DWF viewer print command in the Web Layout has a list of PrintLayout
resource ids which need to be specified. Have you done this?
- Jackie
  _____
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1803224.n2.nabble.com/Problems-with-print-layout-in-DWFview
er-tp6258216p6258267.html
To unsubscribe from Problems with print layout in DWFviewer, click
<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsub
scribe_by_code&node=6258216&code=d2tpbGJ5QHRlbHVzLm5ldHw2MjU4MjE2fDE0NjUwMDY
1OTg=>  here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-print-layout-in-DWFviewer-tp6258216p6258302.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110409/9c283140/attachment.html
