[mapguide-users] RE: [mapguide-trac] #1667: MapGuide Maestro and
Oracle Spatial
Zac Spitzer
zac.spitzer at gmail.com
Wed Apr 27 03:04:49 EDT 2011
The whole point with FDO is that it abstracts aways the specific database
and lets you simply work with the spatial datasets exposed via the
featureSource.
The only database specific item is the way each FDO provider names
the features classes (tables in db speak)
http://trac.osgeo.org/fdo/wiki/FDORfc43
That shouldn't be an issue for what your doing.
So once your have your Oracle FDO connection working, you simply start
creating (authoring) layers and then combining them into creating maps
z
On Tue, Apr 26, 2011 at 11:20 AM, Kiran Korde <kkorde at hotmail.com> wrote:
> Hello Tom,
> Thank you and all for guiding me through to get the setup up
> to establish a connection to Oracle Spatial database. I just need to
> document all the steps I had to implement to get it working.
> Now I have the connection to the database, how do I create layers and then
> display that information in MapGuide. I may sound like a broken record,
> however is there a step by step process of viewing Oracle Spatial data in
> MapGuide? It seems like you and others who had helped me through this
> process has already gone through this process. I would appreciate if you
> could share your knowledge.
> Thanks and Best regards,
> Kiran
> From: thoman at co.gila.az.us
> To: kkorde at hotmail.com; mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] RE: [mapguide-trac] #1667: MapGuide Maestro
> and Oracle Spatial
> Date: Mon, 25 Apr 2011 21:33:12 +0000
> Also, make sure your ORACLE_HOME environment variable is set to the
> install location of your oracle client. Mine happens to be:
> ORACLE_HOME=D:\oracle\product\10.2.0\client_1
> The oracle literature indicates that this is no longer required but I’ve
> found that it’s still frequently referenced.
> As for the TNS error, run through the Oracle configuration to generate the
> tnsnames.ora file found in the client directory. It’s a configuration text
> file found in D:\oracle\product\10.2.0\client_1\NETWORK\ADMIN\tnsnames.ora
> (at least on my machine) It’s a text file so you can check if maybe you’re
> referencing a bad name.
> Hope this helps a little
> Tom
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kiran Korde
> *Sent:* Monday, April 25, 2011 1:12 PM
> *To:* martin.morrison at edsi.com; MapGuide OpenSource
> *Subject:* RE: [mapguide-users] RE: [mapguide-trac] #1667: MapGuide
> Maestro and Oracle Spatial
> Hello Martin,
> I able to get around the error that I had mentioned in my
> earlier post by just downloading and replacing the FDO folder with contents
> from fdosdk-win32-3.3.1.tar.gz
> However I am getting this new error while trying to test the connection
> The remote server returned an error: (559) MgFdoException.:
> An exception occurred in FDO component.
> ORA-12154: TNS:could not resolve the connect identifier specified
> Exception occurred in method MgFdoConnectionManager.Open at line 858 in
> file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> I am able to connect to my Oracle Spatial Database from the command prompt,
> however I get the above mentioned error while trying to test the connection
> from Maestro.
> Any help would be appreciated. Is there a step by step guide/process to
> configure Oracle Spatial Data to display using MapGuide?
> Best regards,
> Kiran
> From: martin.morrison at edsi.com
> Date: Mon, 25 Apr 2011 12:40:04 -0400
> and Oracle Spatial
> Make sure they are located in your system path.
> Martin Morrison
> Application Engineer
> Engineering Design Systems, Inc.
> 3780 Peters Creek Rd Ext SW
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> *Sent:* Monday, April 25, 2011 12:32 PM
> *To:* zac.spitzer at gmail.com; MapGuide OpenSource
> Hello Zac,
> I have installed Oracle 10.2.0.1 client. After running the
> depends.exe, the result came back with 2 missing dlls.
> mscvr80.dll and msvcp80.dll. Should these part of the application package
> that I had downloaded?
> I searched these files and they were found under
> C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2.
> I copied them to \bin and \fdo folder and I still getting the same error.
> Thanks,
> Kiran
> From: zac.spitzer at gmail.com
> Date: Sat, 23 Apr 2011 12:20:27 +1000
> Subject: Re: [mapguide-users] RE: [mapguide-trac] #1667: MapGuide Maestro
> and Oracle Spatial
> what version of oracle libs are you running?
> have you tried running depends.exe on the
> KingOracleProvider.dll ?
> (search the list archives if you need more info
> about depends.exe)
> On Sat, Apr 23, 2011 at 1:00 AM, Kiran Korde <kkorde at hotmail.com> wrote:
> Hello Group,
> I have checked the below mentioned steps and still get the
> error message while trying to select the King.Oracle provider attached in
> the document.
> Here is the snippet from the providers.xml one as suggested by the document
> and the other with actual version number of the file. None of them work.
> This is recommended in the documentation.
> <FeatureProvider>
> <Name>King.Oracle.3.3</Name>
> <DisplayName>King Provider for Oracle</DisplayName>
> <Description>Read/write access to spatial and attribute data in an
> Oracle Spatial.</Description>
> <IsManaged>False</IsManaged>
> <Version>3.3.0.0</Version>
> <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
> <LibraryPath>C:\Program
> Files\MapGuideOpenSource2.0\Server\Bin\FDO\KingOracleProvider.dll</LibraryPath>
> </FeatureProvider>
> Here I have replaced the version number.
> <FeatureProvider>
> <Version>0.8.13.0</Version>
> <FeatureDataObjectsVersion>0.8.13.0</FeatureDataObjectsVersion>
> </FeatureProvider>
> Is there a step-by-step guide to configure and view Oracle Spatial data
> using Mapguide?
> Best regards,
> Kiran
> > From: trac_mapguide at osgeo.org
> > CC: mapguide-trac at lists.osgeo.org
> > Date: Fri, 15 Apr 2011 14:03:24 +0000
> > Subject: Re: [mapguide-trac] #1667: MapGuide Maestro and Oracle Spatial
> > Reporter: kkorde | Owner:
> > Type: defect | Status: closed
> > Priority: high | Milestone: Maestro-3.0
> > Component: General | Version: 2.0.2
> > Severity: major | Resolution: wontfix
> > Keywords: | External_id:
> > Changes (by jng):
> > * status: new => closed
> > * resolution: => wontfix
> > Comment:
> > This error has nothing to do with Maestro and everything with how you've
> > set up the FDO provider. Check the following:
> > 1. The King.Oracle provider you have downloaded is for FDO 3.3.x (this is
> > the version of FDO your MapGuide 2.0.2 is using)
> > 2. You have installed the Oracle Instant Client and that the King.Oracle
> > provider can correctly locate these libraries (OCI.dll). Loading
> > KingOracleProvider.dll into depends.exe can help determine if it can
> > locate these dlls.
> > Please use the mailing list for problems like this in the future.
> > Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1667#comment:1>
> > MapGuide Open Source <http://mapguide.osgeo.org/>
> > MapGuide Open Source Internals
> mapguide-users mailing list
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110427/1223fd96/attachment.html
