[mapguide-users] Re: Maestro 3.5 API Issues
Jackie Ng
jumpinjackie at gmail.com
Fri Dec 2 00:28:38 EST 2011
If you're using Local Native Connection (which is what it looks like from
that stack trace calling into the official API), then it's worth noting that
by default the Local Native Connection assembly still references the old
v2.0.2 MapGuideDotNetApi.dll, which is 32-bit.
Maybe it's worth a try to modify the OSGeo.MapGuide.MaestroAPI.Native
project to replace the old MapGuideDotNetApi reference with your 64-bit
MapGuide .net assemblies and build that modified project.
If not, you should check that you're referencing 64-bit MapGuide .net
assemblies (with the 64-bit unmanaged dlls in the same location)
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Maestro-3-5-API-Issues-tp7050967p7053635.html
