[mapguide-users] Possible BUG using <ParameterOverrides> on Layer
with custom Symbol
Carlos Lacerda
carlos.lacerda at gmail.com
Mon Dec 5 11:56:12 EST 2011
Hi All,
I suspect found a bug on use of ParameterOverrides with custom symbol, this
can make me have to abort the use of mapguide on my project =(
I trying use <ParameterOverrides> to change color of element in my Layer
using field of FeatureClass defined by DataSource KingOra FDO.
To make this solution I use this document of Autodesk as reference:
http://trac.osgeo.org/mapguide/attachment/wiki/AdvancedStylization/building_symbol_libraries.pdf
Below a piece of code I use:
Symbol Definition:
...<Graphics>
<Path>
<Geometry>
M -1,0
A 1,1 0 1 1 1,0
A 1,1 0 1 1 -1,0
</Geometry>
<FillColor>%COR%</FillColor>
<LineColor>%COR%</LineColor>
<LineWeight>0.3</LineWeight>
</Path>
</Graphics>
<PointUsage />
<ParameterDefinition>
<Parameter>
<Identifier>COR</Identifier>
<DefaultValue>FFFF6600</DefaultValue>
<DisplayName>Color line of symbol</DisplayName>
<Description>The color of Symbol.</Description>
<DataType>String</DataType>
</Parameter>
</ParameterDefinition>
Layer Definition:
....<CompositeTypeStyle>
<CompositeRule>
<LegendLabel>TEST</LegendLabel>
<CompositeSymbolization>
<SymbolInstance>
<ResourceId>Library://MG/Symbols/INTERLIG.SymbolDefinition</ResourceId>
<Override>
<SymbolName>INTERLIGADOR</SymbolName>
<ParameterIdentifier>COR</ParameterIdentifier>
<ParameterValue>"COR"</ParameterValue>
</Override>
</ParameterOverrides>
<ScaleX>3000</ScaleX>
<ScaleY>3000</ScaleY>
<SizeContext>MappingUnits</SizeContext>
</SymbolInstance>
</CompositeSymbolization>
</CompositeRule>
</CompositeTypeStyle>
In Layer definition if I set value with a incorrect Field like "XXXXX" the
default color from SymbolDefinition is used, if I set a fixed color value
like FF000000 this color is used correctly, but when I set a Field of my
FeatureClass like "COR",that owns the color definition, the layer not render
nothing, no symbol =(
I did something wrong ??
Anyone already have this problem ?
Can be a bug o FDO driver or where ??
Any help is very apreciated!!
Thanks a lot.
Sds,
Carlos Lacerda
System Architect - CIAS
Brazil
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Possible-BUG-using-ParameterOverrides-on-Layer-with-custom-Symbol-tp7063585p7063585.html
