[mapguide-users] RE: Points from Sql/ODBC data source not showing
soudemans soudemans at ruekert-mielke.com
Tue Dec 6 16:52:12 EST 2011
GordonL wrote
> In your final view in SQL Server 2008, you should just create a Point
> object with your two x and y columns.
> like this:
> /select geometry::Point(g.PNT_X,g.PNT_Y,0) as GEOM
> 	  FROM tbMYTABLE g/
> Then you can use the FDO for SQL Server Spatial rather than ODBC.
Hmm, that didn't work, and then I read the part about SQL Server 2008.
Sorry we are still working in 2005.  Man, what a bummer :(
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7068540.html
