[mapguide-users] RE: SQL Server 2005
Hans Milling
hm at geograf.dk
Wed Dec 7 02:25:18 EST 2011
Hi Michael
Don't hijack a thread.
You can use a regular database table with no geometry/geography column for
displaying e.g. points on a map. If you label the columns x and y the
datasource will detect this automatically when adding the layer. You can
also specify manually in Maestro when adding the datasource I think by
telling which columns in the table has the lat/lng or x/y.
Regards Hans Milling...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQL-Server-2005-tp1806520p7069618.html
