[mapguide-users] Re: Fetching features within rectangle;
layer SRS differs from map SRS
Jackie Ng
jumpinjackie at gmail.com
Thu Dec 8 11:37:09 EST 2011
How did you create your MgMap, with the empty constructor or the one that
accepts a MgSiteConnection?
Because if you use the empty constructor, convenience methods like
MgLayer.GetClassDefinition are not available. The empty constructor itself
is deprecated and should not be used, as you lose access to all convenice
methods.
The convenience methods are outlined here:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc9
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fetching-features-within-rectangle-layer-SRS-differs-from-map-SRS-tp7074044p7074923.html
