[mapguide-users] Unable to select a point using Fusion viewer
Zac Spitzer zac.spitzer at gmail.com
Fri Dec 9 23:41:11 EST 2011
can you try it in firefox with firebug and see if you can see any
further error messages? the embedded IE in studio makes
debugging very hard
On Sat, Dec 10, 2011 at 1:23 AM, Iulia Tamas <iulia_tamas30 at yahoo.com> wrote:
> Hello,
> Message is displayed when selecting a point on the Map using Fusion viewer.
> The data is stored in non-spatial table in Oracle and a primary key is set
> on the table.
> Other layers that use  a .sdf file as a data source can be selected.
> I'm using Mapguide 2.2 on 64 bit machine.
> I've attached an image with the  received message.
> Has anybody encountered the same problem?
> Thank You,
> Iulia
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
