[mapguide-users] MaestroAPI 3 or 4 - How do I get corner coordinates of a RuntimeMap
Hans Milling hm at geograf.dk
Wed Dec 14 07:20:58 EST 2011
Hi all
How do I obtain the corner coordinates of a generated Image.
If I open a RuntimeMap and set these parameters, how can I get the extents
or corner coordinates of the generated image? The coordinates used in my map
are in UTM-32 but I guess that is irrelevant. The MapExtent and DataExtent
seems to be the extent of all the data, and not the current "view".
map.DisplayWidth = 640;
map.DisplayHeight = 480;
map.DisplayDpi = 96;
map.ViewScale = 100000;
map.ViewCenter.X = 574620.0;
map.ViewCenter.Y = 6226838.5;
map.Save();
using (var stream = map.Render("PNG"))
  pictureBox1.Image = Image.FromStream(stream);
Regards Hans Milling...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MaestroAPI-3-or-4-How-do-I-get-corner-coordinates-of-a-RuntimeMap-tp7093318p7093318.html
