[mapguide-users] Re: TCP/IP protocol is mismatched
    soudemans
    soudemans at ruekert-mielke.com
    Fri Dec 16 17:06:37 EST 2011
Thanks Gabriele, and Jackie,
We have tried these ideas and failed.  When we replaced the .dll's with the
latest version, we ran into a 64bit/32bit conflict issue which crippled the
website.  I am trying to resolve this issue with the help of our resident IS
expert, and he concluded that we had to use the 32 bit AjaxToolKit dlls, so
I ended up restoring everything the way it was when I started with this
mess.  I will try to document the reasons for having to use the 32bit
AjaxToolKit on Monday.  I did manage to pinpoint the point of failure which
is exactly as the original thread suggests:
   Dim layer As MgLayer = DirectCast(map.GetLayers().GetItem("Hydrants"),
MgLayer)
Have a nice weekend, and I will "see" you on Monday
Gabriele Monfardini wrote
> Hi,
> StreamIO exception is a sort of collect-all generic exception.
> Wrap your code in a try- catch block and in the catch log the error
> message.
> In PHP it is something like that
> try {
>   //your code
> } catch(MgException $e) {
>   error_log($e->getExceptionMessage(); // in older MapGuides was
> $e->getMessage()
> Regards,
> Gabriele
> mapguide-users mailing list
> mapguide-users at .osgeo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/TCP-IP-protocol-is-mismatched-tp5932934p7102646.html
