[mapguide-users] RE: Problem connecting, but only on one server
_Jon_
jrizzo at Langan.com
Fri Dec 23 11:52:37 EST 2011
I'm not sure that I understand the question. If they are all using the same feature source definition and the same version of FDO, doesn't this mean that they are all using the same client? Please explain.
Thanks,
Jon
From: vd [via OSGeo.org] [mailto:ml-node+s1803224n7122029h56 at n2.nabble.com]
Sent: Friday, December 23, 2011 11:48 AM
To: Jonathan Rizzo
Subject: Re: Problem connecting, but only on one server
I had the same problem times ago. I guess it was a problem with the SQL Server Native Client. Is it the same client on all servers?
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Problem-connecting-but-only-on-one-server-tp7121934p7122029.html
To unsubscribe from Problem connecting, but only on one server, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=7121934&code=anJpenpvQExhbmdhbi5jb218NzEyMTkzNHw0MzQ3NzAwMTI=>.
NAML<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.InstantMailNamespace&breadcrumbs=instant+emails%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
This electronic transmission may contain confidential, proprietary or privileged information. No confidentiality or privilege is intended to be waived or lost by erroneous transmission of this message. If you receive this message in error, please notify the sender immediately by return email and delete this message from your system. Disclosure, use, distribution or copying of this message, any attachments thereto or their contents is strictly prohibited.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-connecting-but-only-on-one-server-tp7121934p7122037.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111223/02822e06/attachment.html
