[mapguide-users] ECW for mapguide 2.2 beta version
Andrew DeMerchant andrew.demerchant at gemtec.ca
Sun Feb 13 19:49:34 EST 2011
You likely don't need to worry - I get that msg every time too...but the layers work just fine (for me at at least).
Andrew
On Feb 13, 2011, at 8:36 PM, ehsan <ehsan85 at yahoo.com> wrote:
> Hi, i'm using mapguide 2.2 beta version and MapGuide Maestro 2.1.4.
> what i'm trying to do is to use ecw file to view in mapguide, using the GDAL
> Provider. the problem is when i validates the current resources it give me
> this error:
> Validating resource: Library://map_terengganu/data_tab/kt.FeatureSource
> Warning - OSGeo.MapGuide.MaestroAPI.FeatureSource: Spatial context extent
> appears to be invalid (or default)
> Thank you..
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/ECW-for-mapguide-2-2-beta-version-tp6022062p6022062.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited.  Disclosure to anyone other than the intended recipient does not constitute waiver of privilege.  If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris  les pièces jointes) est confidentiel et peut être privilégié.  La distribution ou la divulgation non autorisée de ce courriel est interdite.  Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège.  Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
