[mapguide-users] SV: Can't select features using commercial overlays
Peter von Barth peter.vonbarth at eon.se
Wed Feb 16 04:11:54 EST 2011
Yes, all available attributes are checked for selection for this layer. If I remove the google basemap everything works fine, and the attributes are displayed in the selection pane.
Från: Jackie Ng [via OSGeo.org] [mailto:ml-node+6025795-1636546225-314974 at n2.nabble.com]
Skickat: den 15 februari 2011 01:13
Till: Von Barth, Peter
Ämne: Re: Can't select features using commercial overlays
Have you checked that the layer definition in question has any feature attributes checked when selected?
- Jackie
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6025795.html
To unsubscribe from Can't select features using commercial overlays, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6023133&code=cGV0ZXIudm9uYmFydGhAZW9uLnNlfDYwMjMxMzN8MTIyNTA1NjUy>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6030961.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110216/512090e1/attachment.html
