[mapguide-users] SV: Can't select features using commercial overlays
Zac Spitzer zac.spitzer at gmail.com
Wed Feb 16 08:21:15 EST 2011
Your using an older version of Fusion, I would recommend trying
the latest version, which is 2.2
But, the RC3 build has a problem with fusion, RC2 was missing tooltips
and JPEG tiles were broken, the next and hopefully final build will have
both fixed
z
On Thu, Feb 17, 2011 at 12:12 AM, Von Barth, Peter
<Peter.vonBarth at eon.se> wrote:
> I’m using 2.1 and studio 2009
> Från: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] För Zac Spitzer
> Skickat: den 16 februari 2011 11:15
> Till: MapGuide Users Mail List
> Ämne: Re: [mapguide-users] SV: Can't select features using commercial
> overlays
> Which version are you using?
> On Feb 16, 2011 8:11 PM, "Peter von Barth" <peter.vonbarth at eon.se> wrote:
>> Yes, all available attributes are checked for selection for this layer. If
>> I remove the google basemap everything works fine, and the attributes are
>> displayed in the selection pane.
>> Från: Jackie Ng [via OSGeo.org] [mailto:[hidden email]]
>> Skickat: den 15 februari 2011 01:13
>> Till: Von Barth, Peter
>> Ämne: Re: Can't select features using commercial overlays
>> Have you checked that the layer definition in question has any feature
>> attributes checked when selected?
>> - Jackie
>> ________________________________
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6025795.html
>> To unsubscribe from Can't select features using commercial overlays, click
>> here.
>> View this message in context: SV: Can't select features using commercial
>> overlays
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
