[mapguide-users] SetSelectionXML Issue
Greg Neff gbneff at cid.utah.gov
Wed Feb 16 19:15:35 EST 2011
Try taking the quotes out of your .ZoomToView  like this.
parent.parent.ViewerFrame.mapFrame.ZoomToView(<%= lldd %>, <%= urdd %>,
5000, true);
The ZoomToView seems to work either way but having the quotes causes a
javascript error in another mapguide file
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Carrillo, John
Sent: Wednesday, February 16, 2011 4:43 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] SetSelectionXML Issue
               I'm having a couple issue with the code below and I'm
guessing that they are related. I have a map that I created and when I pull
it up initially, I can use the Select Tool and see the Tool Tips on the
layer I'm having issues with, "J_Parcels". But when I run the query below,
the  "SetSelectionXML" doesn't work and I can no longer use the Select Tool
or the Tool Tips in my map. To ZoomToView is working properly but the Parcel
that is queried is not highlighted. I know I'm getting data returned. Not
sure why after the query I can't use the tools or why the SetSelectionXML
isn't working. Also, when I try and Pan or Zoom after the query, the map
goes away, just a blank screen. Any help would be greatly appreciated.
Thanks, JC
    'from the previous page
    Dim sessionId As [String] = Request.Form.[Get]("SESSION")
    Dim encroachPermit As [String] = Request.Form.[Get]("iAPN")
    Dim webLayout As [String] = "Library://JC_Test/WebLayer/J.WebLayout"
    'path to web config
    Dim realPath As String = Request.ServerVariables("APPL_PHYSICAL_PATH")
    Dim configPath As [String] = realPath & "webconfig.ini"
    MapGuideApi.MgInitializeWebTier("C:\Program
Files\AutoDesk\MapGuideEnterprise2011\WebServerExtensions\www\webconfig.ini"
    Dim userInfo As New MgUserInformation(sessionId)
    Dim siteConnection As New MgSiteConnection()
    siteConnection.Open(userInfo)
    Dim resService As MgResourceService =
DirectCast(siteConnection.CreateService(MgServiceType.ResourceService),
MgResourceService)
    Dim featureService As MgFeatureService =
DirectCast(siteConnection.CreateService(MgServiceType.FeatureService),
MgFeatureService)
    'Map from Map Guide
    Dim map As New MgMap()
    map.Open(resService, "J")
    'Query for the second condition
    Dim nameQuery As New MgFeatureQueryOptions()
    nameQuery.SetFilter("APN = '" & encroachPermit & "'")
    'second feature sources to compare first to
    Dim encroachId As New MgResourceIdentifier("Library://Oracle Feature
Source/FCT1TEST_Assessor feature source.FeatureSource")
    Dim featureReader As MgFeatureReader =
featureService.SelectFeatures(encroachId, "PARCELPTS", nameQuery)
    Dim list As New ArrayList()
    Dim x_coordinate As New ArrayList()
    Dim y_coordinate As New ArrayList()
    Dim lldd As Double
    Dim urdd As Double
    While featureReader.ReadNext()
        list.Add(featureReader.GetString("APN"))
        'GET X Y  FROM GEOMETRY
        Dim geometryBytes As MgByteReader =
featureReader.GetGeometry("GEOMETRY")
        Dim agfReader As New MgAgfReaderWriter()
        Dim districtGeometry As MgGeometry = agfReader.Read(geometryBytes)
        Dim env As MgEnvelope = districtGeometry.Envelope()
        lldd = env.GetLowerLeftCoordinate().GetX
        urdd = env.GetLowerLeftCoordinate().GetY
    End While
    Response.Write(list(0) & "<BR />")
    'Highlight the query result on the map
    Dim selection As New MgSelection(map)
    Dim layer As MgLayer = map.GetLayers().GetItem("J_Parcels")
    featureReader = featureService.SelectFeatures(encroachId, "PARCELPTS",
nameQuery)
    selection.AddFeatures(layer, featureReader, 0)
    Dim selectionXML As [String] = selection.ToXml()
<%--<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">--%>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Frameset//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-frameset.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
    <title>H</title>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
    <meta http-equiv="content-script-type" content="text/javascript" />
    <meta http-equiv="content-style-type" content="text/css" />
    <script type="text/javascript">
        function onPageLoad() {
            var selectionXML2 = '<%= selectionXML %>';
            alert(selectionXML2);
            var t = setTimeout("alertMsg()", 9000);
            var t2 = setTimeout("alertMsg2()", 4000);
        function alertMsg() {
            alert('45');
            parent.parent.ViewerFrame.mapFrame.ZoomToView('<%= lldd %>',
'<%= urdd %>', 5000, true);
        function alertMsg2() {
            alert('45');
parent.parent.ViewerFrame.mapFrame.SetSelectionXML(selectionXML2);
    </script>
</head>
<body id="body1" class="AppFrame" onload="onPageLoad()">
    <strong>The following are the query results: </strong>
    <ul>
            For i As Integer = 0 To list.Count - 1
                Dim address As [String] = list(i).ToString()
                If address <> "" Then
                    Response.Write("<li>" & list(i).ToString() & "</li>" &
vbLf)
                End If
            Next
    </ul>
    <iframe id="imap"
src="/mapguide2011/mapviewernet/ajaxviewer.aspx?SESSION=<%=
sessionId %>&WEBLAYOUT=<%= webLayout %>" name="ViewerFrame" height="700"
        width="1200" scrolling="yes" />
</body>
</html>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110216/a7eba8a1/attachment.html
