[mapguide-users] help with Getmapimage
Birgir
bgu at geograf.dk
Mon Feb 21 05:28:28 EST 2011
hi there,
Im trying to create an image from a selection and I need some help with
getmapimage.
Ive attached an image that helps describe what I want to accomplish.
I want to be able to select an area with for example a polygon and create an
image that shows that selection. Currently I am doing this except the image
shows much more then just the selection.
I cant just change the setdisplaywidth because that just changes the size of
the image and I need the image to be ca. width=400 and height=500.
The following is how I create my image.
Dim Img As String = "http://localhost/mapguide2009/mapagent/mapagent.fcgi?"
& _
"OPERATION=GETMAPIMAGE&VERSION=1.0.0" & _
"&FORMAT=PNG&SESSION=e3162e34-ffff-ffff-8000-005056c00001_da_7F0000010AF20AF10AF0&"
& _
"MAPNAME=Kort_temaer" & _
"&SETVIEWCENTERX=517334,984521116" & _
"&SETVIEWCENTERY=6315357,04906777" & _
"&SETVIEWSCALE=200000" & _
"&SETDISPLAYWIDTH=400" & _
"&SETDISPLAYHEIGHT=500"
http://osgeo-org.1803224.n2.nabble.com/file/n6048188/GETMAPIMAGE_test.png
thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/help-with-Getmapimage-tp6048188p6048188.html
