[mapguide-users] Re: SV: SV: Can't select features using commercial overlays
Peter von Barth peter.vonbarth at eon.se
Tue Feb 22 05:44:45 EST 2011
one more try.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>EON MapServer</title>
<meta http-equiv="Content-type" content="text/html; charset=UTF-8">
<script
src="http://api.maps.yahoo.com/ajaxymap?v=3.0&appid=XTe_dDTV34GFsx8sj3w_4qL76z6iBUbb2aDtNVomGFqmPvHGJZcPgxXonL5r0o26upg1Vg--"></script>
<script
src="http://maps.google.com/maps?file=api&amp;v=2&amp;sensor=false&amp;key=ABQIAAAAPrUgD2WqQisUBUMCKnkU4xSVrovqgKLmREEerE6ydUcQmn1bWRRVk_HRx5hbgGGAMBOXKn99Z9iU8Q"
type="text/javascript"></script>
<script
src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1'></script>
<script type="text/javascript"
src="../../../lib/fusionSF-compressed.js"></script>
<link rel="stylesheet" href="jxtheme.css" type="text/css" media="screen"
charset="utf-8">
<!--[if lte IE 6]>
<link rel="stylesheet" href="ie6.css" type="text/css" media="screen"
charset="utf-8">
<![endif]-->
<!--[if IE 7]>
<link rel="stylesheet" href="ie7.css" type="text/css" media="screen"
charset="utf-8">
<![endif]-->
<link rel="stylesheet" href="icons.css" type="text/css" media="screen"
charset="utf-8">
<script type="text/javascript">
var panel1;
var panel2;
var panel3;
var panel4;
var panelman;
window.onload = function() {
    Fusion.initializeLocale();  //need to call this first if
String.Translate is to be used in the onload
    var main = new Jx.Layout('AppContainer');
    new Jx.Layout('FileMenu', {
        left: 5,
        right: 5,
        top: 5,
        height: 25
    new Jx.Layout('Toolbar', {
        left: 5,
        right: 5,
        top: 30,
        height: 24
    new Jx.Layout('ToolbarVertical', {
        left: 5,
        width: 28,
        top: 54,
        bottom: 21
    new Jx.Layout('SplitterArea', {
        left: 33,
        top: 54,
        right: 5,
        bottom: 22
    new Jx.Layout('MapArea');
    new Jx.Layout('Map');
    new Jx.Layout('StatusbarContainer', {
        height: 22,
        bottom: 0,
        top: null
    new Jx.Layout('Statusbar', {
        right: 159
    var splitter = new Jx.Splitter('SplitterArea', {
        splitInto:2,
        elements:[$('MapArea'),$('Sidebar')],
        layout:'horizontal',
        containerOptions: [{},{minWidth:8, width: 218}],
        barOptions: [
                snap: 'after',
                snapElement: $('SidebarCollapse'),
                snapEvents: ['click']
  /* create dynamic content */
  panel1 = new Jx.Panel({
      label: OpenLayers.i18n('legendTitle'),
      collapse: false,
      maximize: true,
      contentId: 'Legend'});
  panel1.content.id = 'Legend';
  panel2 = new Jx.Panel({
      label: OpenLayers.i18n('selectionPanelTitle'),
      collapse: false,
      maximize: true,
      contentId: 'SelectionPanel'});
  panel3 = new Jx.Panel({
      label: OpenLayers.i18n('taskPaneTitle'),
      collapse: false,
      maximize: true,
      contentId: 'TaskPane'});
  panel4 = new Jx.Panel({
      label: OpenLayers.i18n('ovmapTitle'),
      collapse: false,
      maximize: true,
      contentId: 'OverviewMap'});
  panelman = new Jx.PanelSet({parent: splitter.elements[1], panels: [panel1,
panel2, panel3, panel4]});
  main.resize();
  Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED,
fusionInitialized);
  Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
  Fusion.initialize();
var fusionError = function(eventId, error) {
    alert('Fusion Error: \n' + error.toString());
    //console.log('Fusion Error: \n' + error.toString());
var fusionInitialized = function() {
    $('AppContainer').resize({forceResize: true});
var showOverviewMap = function() {
  panelman.maximizePanel(panel4);
var showTaskPane = function() {
  panelman.maximizePanel(panel3);
var showLegend = function() {
  panelman.maximizePanel(panel1);
var showSelectionPanel = function() {
  panelman.maximizePanel(panel2);
</script>
</head>
<body>
<div id="AppContainer">
  <div id="FileMenu"></div>
  <div id="SplitterArea">
    <div id="MapArea">
      <div id="Map"></div>
      <div id="Navigator"></div>
    </div>
    <div id="Sidebar">
      <!-- Collapse Sidebar -->
      <div id="SidebarCollapse">
      </div>
    </div>
  </div>
  <div id="Toolbar"></div>
  <div id="ToolbarVertical"></div>
  <div id="StatusbarContainer">
    <div id="Statusbar"></div>
    <div id="pbmg"> images/pbmg.gif </div>
  </div>
</div>
<div id="Maptip"></div>
</body>
</html>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-select-features-using-commercial-overlays-tp6023133p6051867.html
