[mapguide-users] Re: WMS - A length exception occurred: string too
long
ar_gaeta
ar_gaeta at yahoo.it
Tue Feb 22 06:11:24 EST 2011
Using mapadmin I activate the trace.log and set the error.log to archive the
file every day with all the information available, that are:
CLIENT, CLIENTIP, USER, ERROR, STACKTRACE
Now I've also set as "Maximum features cached" (in "Configure Services")
instead of 100 I put the value of 1000 (I don't know if helpful).
I've restarted the Apache service, and for a while the WMS works. But again
after a while it stops to work, without reasons! I restart Apache, and WMS
works: maybe the problem is in my Apache-Tomcat configuration?
When WMS failed, I've got on OpenLayer broken images:
http://osgeo-org.1803224.n2.nabble.com/file/n6051932/broken_wms.jpg
And again the message:
"A length exception occurred. string too long"
I attach my WMS_getcapabilities response xml file: my layer is "staz_piem"
at rows 273-296.
Maybe the WMS broke because I've specified the SRS EPSG:900913 and it is not
recognized by MGOS? How can MGOS recognize this EPSG? Reading some post I've
understood that maybe I have to work on the file "OgcWmsService.config.awd"
on the "<translate from="EPSG:21781">" tag: is this right?
Thanks for your help!
http://osgeo-org.1803224.n2.nabble.com/file/n6051932/mapagent.fcgi.xml
mapagent.fcgi.xml
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMS-A-length-exception-occurred-string-too-long-tp6051670p6051932.html
