[mapguide-users] Re: Mapguide and web services
Jackie Ng jumpinjackie at gmail.com
Tue Feb 22 07:17:13 EST 2011
Unfortunately, I don't use java so whatever advice I can give is limited.
What I can do however is point you to some of the possibly relevant classes
in the MapGuide API:
- MgMap (holds the state of the map you are currently looking at)
- MgRenderingService (used to render images of the MgMap)
- MgByteReader (returned from MgRenderingService and contains the rendered
image data)
Hope that helps.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapguide-and-web-services-tp6051893p6052135.html
