[mapguide-users] Re: Syntax to set Active layer in Mapguide via
Fusion
Michael Adair
madair at dmsolutions.ca
Tue Feb 22 09:57:40 EST 2011
The get/setActiveLayer methods are in the Map object (ie. the
Fusion.getWidgetById('map') object) since the active layer can be set to
any of the layers (ie. more than just aMaps[0])
Mike
On 21/02/2011 6:31 AM, BTenBroeck wrote:
> No, I'm trying to set a layer active, and then tell the selection tool
> to only use items on the active layer. I have the second piece working
> , but I don't want the user to have to manually set the layer active.
> On 2/20/2011 7:39 PM, zspitzer [via OSGeo.org] wrote:
>> what are you trying to do, turn a layer on?
>> On Mon, Feb 21, 2011 at 2:39 AM, BTenBroeck <[hidden email]
>> </user/SendEmail.jtp?type=node&node=6047126&i=0&by-user=t>> wrote:
>> > Hello all. This is a cross-post from the Fusion-users, as I had no
>> luck
>> > getting a response there. Hopefully the heavier traffic over here
>> may bear
>> > fruit. :)
>> > As the subject says, I'm trying to figure out the appropriate
>> syntax to
>> > set the active layer via Javascript in Fusion.
>> > What I've tried is:
>> > var oMap = Fusion.getWidgetById('Map').aMaps[0];
>> > var activeLayer = oMap.setActiveLayer("Parcels");
>> > which seems like it's appropriate by looking at the Map.js widget.
>> > However, it tossess an error, and if I view in Firebug, there is no
>> method
>> > in oMap for
>> > setActiveLayer or getActiveLayer as I would expect.
>> > If anyone has a clue, or can point me in the right direction, I would
>> > appreciate it.
>> > Thanks
>> > View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6045953.html
>> <http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6045953.html?by-user=t&by-user=t>
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > [hidden email]
>> </user/SendEmail.jtp?type=node&node=6047126&i=1&by-user=t>
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
>> [hidden email]
>> </user/SendEmail.jtp?type=node&node=6047126&i=2&by-user=t>
>> If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6047126.html
>> <http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6047126.html?by-user=t>
>> To unsubscribe from Syntax to set Active layer in Mapguide via
>> Fusion, click here
>> <http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6045953&code=YmlsbHRlbmJyb2Vja0BnbWFpbC5jb218NjA0NTk1M3w1MzM0ODEyNTU=&by-user=t>.
> View this message in context: Re: Syntax to set Active layer in
> Mapguide via Fusion
> <http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6048362.html>
> <http://osgeo-org.1803224.n2.nabble.com/MapGuide-Users-f1803227.html>
> at Nabble.com.
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110222/03af3bd2/attachment.html
