[mapguide-users] RE: Raster provider
Martin Morrison martin.morrison at edsi.com
Mon Feb 28 08:43:22 EST 2011
Why submit this as a blocker to 2.2 at this late stage?  It has been the behavior for all versions so far.  I view this as an enhancement, not a last minute fix to get 2.2 out.  Why not set it for 2.3?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Saturday, February 26, 2011 11:16 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] RE: Raster provider
I have reopened the following ticket
#740 (GETSPATIALCONTEXTS and GDAL Always Returns Default Extents)
http://trac.osgeo.org/mapguide/ticket/740
On Wed, Feb 23, 2011 at 12:50 AM, Trevor Wekel
<trevor_wekel at otxsystems.com> wrote:
> As far as I know, all versions of MapGuide Open Source and the GDAL Raster
> Provider do require manual override of CS and map settings.  It is a defect
> that needs to be looked at in more detail.  MapGuide/GDAL is functional but
> definitely quirky.
> Funding or donations would help offset investigation/development costs.
> Please contact me offline if you are interested.
> One other thing to note -  MapGuide/GDAL is mostly single threaded.  Under
> load tests, scalability is limited to approximately 2 cores of CPU.
> Regards,
> Trevor
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ivan Milicevic
> Sent: February 22, 2011 12:18 AM
> Subject: [mapguide-users] RE: Raster provider
> Thank you, I'll try that.
> Does anyone know, which one MG version is working fine with rasters? I can
> not tell customers to manualy override CS and map settings.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
