SV: [mapguide-users] Re: Draw a line?
Markus Persson
Markus.Persson at vitec.se
Mon Feb 28 10:15:50 EST 2011
I guess you refeer to http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/MgOpenSourceDevGuide.pdf ?
I looked at it and found a chapter called "Redlining". However, the text there uses PHP. And the example send information to a draw_line.php, which in turn uses common.php, layerdefinitionfactory.php and layer_functions.php.
I want something in ASP, does this exist?
Isn't there a simple MG command that just accepts two coordinates (x0y0, x1y1) and draws a line?
If you mean another sample, please point me in the right direction (a link would be helpful).
-----Ursprungligt meddelande-----
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Mauricio Villablanca
Skickat: den 25 februari 2011 11:21
Till: mapguide-users at lists.osgeo.org
Ämne: [mapguide-users] Re: Draw a line?
Yes it is. Look at the samples to see how it's done.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Draw-a-line-tp6063685p6064017.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
