[mapguide-users] MGOS 2.2 RC2?
Zac Spitzer zac.spitzer at gmail.com
Wed Jan 5 18:51:44 EST 2011
I just tried the java install option and the java mapviewer didn't work
after install
I'm trying out Trevor's GDAL notes ( with tiled maps)
z
2010/12/3 Andrew DeMerchant <andrew.demerchant at gemtec.ca>
>  Thanks Trevor - I'll play around with that setup and post my experiences
> under the ticket. Thanks for the info!
> On 10/12/02 9:44 AM, Trevor Wekel wrote:
>  Hi Andrew,
> I was hoping to get GDAL in MapGuide 2.2 resolved before the RC2 but that’s
> probably not realistic.  I will start the RC2 build on the weekend.
> I did some digging into the GDAL provider  and have discovered that using a
> different build of GDAL seems to open up some raster formats with MapGuide
> 32 bit installed on Windows 64 bit.  I haven’t had time to run multiuser
> load tests with the updated GDAL libraries so I do not know if this is a
> stable configuration.  I haven’t got a lot of uptake on funding for the GDAL
> provider recently so I am working on it in my spare time.
> I have written some configuration details into
> http://trac.osgeo.org/mapguide/ticket/1476.  If you have time and a spare
> machine I could certainly use some help with testing.  If you have trouble
> downloading the libraries, please ping me offline.
> Regards,
> Trevor
> *From:* mapguide-users-bounces at lists.osgeo.org [
> mailto:mapguide-users-bounces at lists.osgeo.org<mapguide-users-bounces at lists.osgeo.org>]
> *On Behalf Of *Andrew DeMerchant
> *Sent:* December 1, 2010 12:54 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] MGOS 2.2 RC2?
> I sent this a couple of weeks ago - never heard anything about 2.2 or RC2
> timelines...Any word?
> Andrew
> On 10/11/18 9:16 AM, Andrew DeMerchant wrote:
> Just wondering about the timeline for RC2....RC1 has a few bugs that
> prevent me from using it at all (sadly!), and I know that most of my
> blockers have been fixed (the only one not dealt with yet is the GDAL plugin
> freezing problem - I highly doubt that one will be fixed in 2.2, at this
> rate). Not having the tools to make my own build, an RC 2 would let me (and
> those in the same position) test more things out. I was only able to test
> out RC1 for a couple of days, until I hit my roadblocks.....Anyway, just
> looking for some idea on when this (or the final version of 2.2) might be
> rolling out. Thanks!
> Andrew
> [image: GEMTEC Limited] <http://www.gemtec.ca/>
> *Andrew DeMerchant*
> tel: 506.453.1025  /  toll-free: 1.877.243.6832
> fax: 506.453.9470
> This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited.  Disclosure to anyone other than the intended recipient does not constitute waiver of privilege.  If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
> Ce courriel (y compris  les pièces jointes) est confidentiel et peut être privilégié.  La distribution ou la divulgation non autorisée de ce courriel est interdite.  Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège.  Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> *Andrew DeMerchant*
> fax: 506.453.9470
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> fax: 506.453.9470
> records.
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110106/44c32873/attachment.html
