[mapguide-users] GetPropertyType (php) not working in 2.x?
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Jan 14 09:21:11 EST 2011
Hi Andrew,
It should work and return an integer from the MgPropertyType "enumeration class". What are you seeing?
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew DeMerchant
Sent: January 13, 2011 5:00 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] GetPropertyType (php) not working in 2.x?
Not sure - I wanted to check before making a ticket...my php skills aren't exactly great. I just wanted to see if other people are using it successfully, first.
Andrew
On 1/13/2011 7:57 PM, Zac Spitzer wrote:
still failing in 2.2 RC2 ? is there a ticket in trac?
2011/1/14 Andrew DeMerchant <andrew.demerchant at gemtec.ca<mailto:andrew.demerchant at gemtec.ca>>
I had posted this a couple of years ago now, and never got a reply - I'd ended up just working around this....but it's come up again. Any idea why this line would be failing?
Andrew
On 08/07/23 10:49 AM, Andrew DeMerchant wrote:
Does the FeatureReader no longer support the GetPropertyType method in 2.0? This line (taken right from the webapi documentation) doesn't work for me:
$propertyType = $featureReader->GetPropertyType($propertyName);
Andrew
[https://mail.google.com/mail/u/0/?ui=2&ik=bab9b6b23d&view=att&th=12d81570271b923a&attid=0.0.1.1&disp=emb&zw]<http://www.gemtec.ca/>
Andrew DeMerchant
tel: 506.453.1025 / toll-free: 1.877.243.6832
fax: 506.453.9470
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited. Disclosure to anyone other than the intended recipient does not constitute waiver of privilege. If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris les pièces jointes) est confidentiel et peut être privilégié. La distribution ou la divulgation non autorisée de ce courriel est interdite. Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège. Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110114/9b66d15e/attachment.html
