[mapguide-users] MrSID and ECW images fail to display in MapGuide 2.1!
Zac Spitzer zac.spitzer at gmail.com
Sun Jan 16 20:37:53 EST 2011
this issue can be safely ignored, if you do a google search
you will see that the this error relates only to the legend
http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg16920.html
make sure that the co-ordinate system is being read properly from your
feature source, mapguide and GDAL has problems with this.
You will probably need to override the CS in the feature source to
the actual CS for the source data
Regards
Zac
On Mon, Jan 17, 2011 at 6:20 AM, wangyunli <wangyunli at 163.com> wrote:
> hello
>     i am learning mapguide open source 2.1,which can not display MrSID and
> ECW images,could you help me what can i do?
>  thanks
> Error log:
>  Error: An exception occurred in FDO component.
>         Only MOSAIC(), CLIP() and RESAMPLE() are supported.
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation() line 83 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpSelectFeaturesSpatial.Execute() line 110 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>   - MgServerSelectFeatures.SelectFeatures() line 250 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> 2011-01-17
> ________________________________
> wangyunli
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
