[mapguide-users] Re: Fusion Tutorials - OpenLayers not Defined
Nathan Elmore elmore.nathan at gmail.com
Wed Jul 6 13:00:02 EDT 2011
It appears that something went wrong with the fusion installation that came
with the MGOS 2.2 binaries. I installed a fresh fusion version 2.2 under
www/fusion2 and used that. So far, the tutorials that come with fusion are
working fine now.
-N
On Wed, Jul 6, 2011 at 9:13 AM, Nathan Elmore <elmore.nathan at gmail.com>wrote:
> Right. I am using the Fusion Learning Materials zip archive from the 2.0
> version (it says the 2.1 version is in progress and not available). I also
> tried the tutorial from the
> http://trac.osgeo.org/fusion/wiki/MapGuideTutorial and I get similiar
> results.
> Where can I find documentation for MGOS2.2, even if it is incomplete?
> Thanks
> On Tue, Jul 5, 2011 at 7:11 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
>> What MGOS Fusion tutorials are you referring to? I would wager the
>> documentation is out of date.
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Fusion-Tutorials-OpenLayers-not-Defined-tp6551714p6552667.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110706/fc2f9e09/attachment.html
