[mapguide-users] ApplicationDefinition.xml in Fusion
Olcay Ebcin (Coğrafi Bilgi Sistemleri Şube Müdürü)
OEBCIN at iski.gov.tr
Tue Jul 12 14:07:34 EDT 2011
Hello,
I'm trying to make fusion application example using sheboygan map.
I would like to run javascript codes under widgets directory. For example zoom in or zoom out.
But I couldnt make any connection between index.html and javascript codes(zoom.js)
I thought ApplicationDefinition.xml is for this purposes. However even I delete ApplicationDefinition.xml and widgets directory,
it still works.
I read a lot about fusion documentation. But still couldnt understand how index.html and ApplicationDefinition.xml file works together.
I need to understand the logic.
My url link and index.html file below
Regards,
Olcay Ebcin
http://localhost/mapserver2012/fusion/templates/mapguide/example/index.html?ApplicationDefinition=Library://Samples/FlexibleWebLayouts/Examples.ApplicationDefinition
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>Hello Sheboygan</title>
<!-- change the source of the following tag to point to your fusion installation -->
<script type="text/javascript" src="../../../lib/fusionSF-compressed.js"></script>
<script type="text/javascript">
window.onload = function() {
Fusion.initialize();
var main = new Jx.Layout('AppContainer');
new Jx.Layout('Map', {left: 228});
main.resize();
</script>
</head>
<body>
<div id="AppContainer">
<div id="ZoomIn">zoomin</div>
<div id="ZoomOut">zoomout</div>
</div>
<div id="Map" style="position: relative; width: 400px; height: 400px"></div>
</div>
</body>
</html>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110712/a15d9018/attachment.html
