[mapguide-users] RE: Compile Error: An attempt was made to load a program with an incorrect format.
DanielDu daniel.du at autodesk.com
Fri Jul 15 23:21:32 EDT 2011
To hide  this error message on 64bit, you can try using WebApplication
instead of Website, and run your webapplication on local IIS instead of the
webserver of VS2010, as VS2010 is still a 32bit application, as well as the
internal webserver released with vs2010.
please refer to the webcast for a live demonstration :
http://download.autodesk.com/media/adn/AIMS2012_Webcast_English/AIMS2012_Webcast_English.html
And download the recording and code sample at
http://download.autodesk.com/media/adn/AIMS2012_Webcast_English.zip
Hope this helps some.
Daniel Du
Autodesk Developer Network
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Compile-Error-An-attempt-was-made-to-load-a-program-with-an-incorrect-format-tp6153978p6588678.html
