[mapguide-users] RE: MGOS 1.2.0 Filter On Joined Field
Mike Micallef
Michael.Micallef at ontario.ca
Tue Jul 26 15:12:41 EDT 2011
I have a question for 2.2 / 2.1-
Currently I am
Version 2.1.0.4283
on Apache
For the past several versions, I have not been able to get past an FDO
exception when working with ODBC
connections from MSaccess when searching.
For both shapefile joined (for polygon/line information) and straight X,Y
reads (x,y in the Access Database)
with MS Access Databases - the layers do render properly and all data is
available when selecting
(identifying) in the properties window - but i have not been able to
succesfully search against the ODBC
data that is joined or by itself.
I have tried several things but no getting rid of the error...
Any ideas - I have seen a couple posts about seaching against ODBC for past
versions but nothing specific
on why you cannot seach the data (mostly on selecting via the API).
Is searching a joined shapefile and MSaccess table supported in version 2.1?
Is searching a joined shapefile and MSaccess table supported in version 2.2?
If so in either case - does anyone have any ideas on how to make this work
or if more specifically it should/shouldn't ever work?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGOS-1-2-0-Filter-On-Joined-Field-tp1812320p6623358.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110726/be1a009a/attachment.html
