[Bulk] [mapguide-users] Best way to incorperate non-spatial data
from adatabase?
Murph
cad4703 at bellsouth.net
Wed Jun 1 09:06:35 EDT 2011
Times like this I miss being a part of SCADA, after all CAD is the center of
SCADA.
Murph
http://map3d.wordpress.com/
----- Original Message -----
To: <mapguide-users at lists.osgeo.org>
Sent: Wednesday, June 01, 2011 7:55 AM
Subject: [Bulk] [mapguide-users] Best way to incorperate non-spatial data
from adatabase?
> Right now I have two data sources. A static SHP Feature Source and ODBC
> Feature Source connected to Microsoft SQL Server 2008 R2. The shape files
> contain static meter locations, while the database will have hourly meter
> load data that will be updated every hour.
> I want the meter load data to appear on each meter in the map. The shape
> file and the database both have a field called "MTR_NUM" that they can be
> joined with. I can set up an ODBC Feature source and join it with the
> shape
> file resource seemingly just fine in Maestro 3.0, but when I try viewing
> the
> layer in the map mapguide freezes up and I need to restart my dev machine
> to
> try to get it to work again.
> I am on the right track? Should I be trying integrate my shape file info
> into the database and use a MS SQL Server Spatial feature source instead?
> If
> so, how would I do that?
> Thanks for your time,
> Jamie
> http://osgeo-org.1803224.n2.nabble.com/Best-way-to-incorperate-non-spatial-data-from-a-database-tp6426773p6426773.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
