[mapguide-users] Re: Feature join in SQL Server 2008
GordonL
gordon.luckett at arrowgeomatics.com
Mon Jun 6 17:06:58 EDT 2011
Hi Jon,
I you have a table in SQL Server that contains your Geography/Geometry
column, you can join it to another table using a "VIEW". A query is a saved
Query (like in Microsoft Access) that you can use.
You can use SQL to connect the KEY in your table (i.e. PARCEL_ID or GIS_ID)
to the KEY in the other table.
For Example, I have two tables:
1. TEMPEST_LAND
2. GIS_PARCEL
TEMPEST_LAND has all my address info and it has a key column called GIS_LINK
GIS_PARCEL has all my graphics (GEOG) and it has a key column called GIS_ID
Create a new VIEW called vwLANDPARCEL
SELECT dbo.TEMPEST_LAND.ADDRESS, dbo.GIS_PARCEL.GEOM,
dbo.GIS_PARCEL.GIS_ID
FROM dbo.TEMPEST_LAND INNER JOIN
dbo.GIS_PARCEL ON dbo.TEMPEST_LAND.GIS_LINK =
This would give your only the parcels that match in the TEMPEST_LAND table.
You can then point MapGuide to this new view called vwLANDPARCEL
Now if you want to make the parcels selectable, you will have to check out
Jackie's FDO Schema Overrides
http://themapguyde.blogspot.com/2010/08/using-fdo-schema-overrides.html
Too bad joins within mapguide are too pokey.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Feature-join-in-SQL-Server-2008-tp6446417p6447010.html
