[mapguide-users] Re: Layer label
Jason Birch jason at jasonbirch.com
Wed Jun 8 02:24:42 EDT 2011
MapGuide/FDO don't have a concept of a "text" or annotation data type, so
it's unlikely that the features would map across properly.
While I've had success using FME to convert MapInfo text into points in an
SDF file that can be labelled in MapGuide, I'm not sure of any open source
tools for doing this.  I didn't even attempt to do direct read; was pretty
sure that I wouldn't get the control or performance I wanted.
Jason
On 7 June 2011 21:33, ehsan <ehsan85 at yahoo.com> wrote:
> Did you mean layer styles? yes. i had tried styling the display point
> label,
> but the layer properties only have ID, FID..i would like to make it show
> same label as map info default.
> It is possible to make mapguide maestro match the map info defaults?
> Thanks.
> http://osgeo-org.1803224.n2.nabble.com/Layer-label-tp6452226p6452319.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110607/d8697090/attachment.html
