[mapguide-users] Re: Fusion Viewer Error
Greg
gbneff at cid.utah.gov
Fri Jun 10 11:19:26 EDT 2011
To answer your question; I think it is the cs code. I have tried setting the
coordinate system from Maestro using "Select by list" and "Type coordinate
system code". I have also set it using Mapguide Studio 2011.
Maestro shows the coordinate system as this:
PROJCS["WI83-CF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["false_easting",1968500.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",-90.00000000000000],PARAMETER["latitude_of_origin",43.83333333333333],PARAMETER["standard_parallel_1",45.50000000000000],PARAMETER["standard_parallel_2",44.25000000000000],UNIT["Foot_US",0.30480060960122]]
Jackie Ng wrote:
> What feet-based coordinate system did you use (cs code and/or EPSG code)?
> - Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-Viewer-Error-tp6454124p6462633.html
