[mapguide-users] Re: How to realize the dynamic segment function
in MGOS?
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 14 03:09:04 EDT 2011
if you are using PostGIS try PgRoute
On Tue, Jun 14, 2011 at 5:06 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> A high-level process flow would be something like this off the top of my
> head:
> Create a MgCoordinateSystem object from the SRS of your MgMap
> With the MgGeometry instance in question (representing the highway), start
> from the first coordinate and use the measuring functionality of your
> MgCoordinateSystem to measure the distance between each coordinate, tallying
> up the running total distance. Once this running total distance passes
> 22.3km, measure the distance between the current coordinate and the
> previously sampled one to determine which coordinate is closest to the
> 22.3km mark. The coordinate closest to this mark would be the coordinate you
> are after.
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-realize-the-dynamic-segment-function-in-MGOS-tp6472870p6472985.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
