[mapguide-users] Re: re; projection in mapguide
Jackie Ng jumpinjackie at gmail.com
Tue Jun 14 07:25:40 EDT 2011
You have not told us what the coordinate system of your layer feature source
is and what the coordinate system of your Map Definition is.
If they are different, you should be inserting markers using the coordinates
based on the coordinate system of the *layer feature source* and not the Map
Definition, as non-matching layers are transformed on-the-fly to match the
coordinate system of your Map Definition.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/re-projection-in-mapguide-tp6473598p6473613.html
