[mapguide-users] Re: Dynamically Setting Initial Map Position and
Scale
pwong
previn.wong at sce.com
Wed Jun 15 11:16:02 EDT 2011
When I try "ToString()", I also get an error.
Problem:
The application encountered a problem and could not finish the operation you
just requested properly.
Solution:
If it\'s the first time you met this problem, try again or restart the
application / session; otherwise, describe the steps to reproduce this
problem to the server administrator for suggestions.
I also tried Rewind() for the ByteReader before setting the new resourceid
in case it had read all the way through.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Dynamically-Setting-Initial-Map-Position-and-Scale-tp1818865p6479268.html
