[mapguide-users] Re: MapGuide + Progress DB
Jackie Ng jumpinjackie at gmail.com
Thu Jun 16 05:38:33 EDT 2011
Does Progress DB have ODBC drivers?
If so, you *may* be able to use the ODBC FDO provider, but success in
reading such data is unknown.
But the utility of such connectivity is limited because ODBC provider can
only support point geometries (via X/Y/Z columns) and if live integrating
with other spatial data, will almost definitely require the use of feature
joins which are buggy and has terrible performance.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MapGuide-Progress-DB-tp6482090p6482342.html
