[mapguide-users] Help concat
berio
salisav at libero.it
Wed Jun 22 10:39:20 EDT 2011
Good morning everyone, I'm new and I do not speak English very well but I
hope you can help me too, hope not to have mixed up the mailing lists.
I have a problem I have to plug 100. Pdf file in an access db linked via
ODBC Mapguide OS, before posting I looked at previous discussions but I did
not understand much.
Within the access db I have created a text field that says the names of the
pdf file, what I get from SELECT is that the field with the pdf is on and I
open the attached pdf.
Are not very practical programming so I would like you explained to me step
by step the expressions to be written with the Maestro.
I realized that I have to use Concat but how?
The folder that contains the pdf files should be placed where?
Using Mapguide OS 2.2, Maestro 3.1, win7 pro x64.
Thanks for your help.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Help-concat-tp6504532p6504532.html
