[mapguide-users] Re: Using MG_DATA_PATH_ALIAS
    Jason Birch
    jason at jasonbirch.com
    Wed Jun 29 04:23:20 EDT 2011
Hi Steve,
What you're showing is the feature source.  The raster providers (both
Autodesk and GDAL) also support a sidecar configuration document that lists
the filenames and extents for an entire set of images, improving the
performance when you're zoomed in.  Basically, the provider does a quick
check between the requested extents and those in the config file to narrow
down the images that need to be requested.
Jason
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110629/cc4d21b6/attachment.html
