[mapguide-users] MapGuide Open Source 2.2 Release Candidate 4 released
Andrew DeMerchant andrew.demerchant at gemtec.ca
Sat Mar 19 14:28:59 EDT 2011
I'm not setup to build - so I can't do any patching...I could certainly
do some testing though, if someone could get me a test build.
In other news, I just installed IE9 and tested out on my server which is
running MGOS v2.2.0.5354 (I think that's RC2)....worked perfectly fine
for me. My site's AJAX though - could be that the guy that posted about
this problem was either a) using Fusion (which I can't test right now,
since I don't have any Fusion sites), or b) had a beta of IE9 which was,
indeed, broken.....or maybe c) that the version after 2.2.0.5354 breaks
IE9 compatibility, I suppose. Though, that seems unlikely.
Anyway - I just wanted to give my 2cents on this...I just think that we
should make sure that either MGOS 2.2 supports all major browsers out of
the box, or else gets a patch asap - I'm not sure when IE9 will be
pushed out through Windows Update and WSUS, but when it does, we need to
be sure that MGOS is up to snuff for it.....like I said, from what I can
tell at the moment, it seems to work fine (or worst case, worked fine
very recently).
Andrew
On 19/03/2011 11:53 AM, Zac Spitzer wrote:
> Alas. the ie9 fixes were made on trunk 4 months ago
> http://trac.osgeo.org/mapguide/search?q=ie9&noquickjump=1&changeset=on
> I believe the 2.2 branch was cut 5 months ago
> Andrew, can you apply and test those change sets over a RC4 install?
> z
> On Sun, Mar 20, 2011 at 12:42 AM, Trevor Wekel
> <trevor_wekel at otxsystems.com>  wrote:
>> Hi Andrew,
>> I believe there are some IE9 fixes present in the RC4 build and likely more to come.  I was not planning on holding back the 2.2.0 release for IE9 support.  I do agree it is an important feature.  We are already thinking about timing and content for a 2.2.1 bug fix release.
>> Bug fix release?  What's that?  We haven't had one of those since 2.0.2 (2.5 years ago).  Most open source projects have bug fix releases every quarter.  Releases and bug fixes are certainly one area where funding either by direct contract work or through Sponsorships/Donations would certainly help.
>> At the moment, we barely manage a single release every year.  The 2.2.0 release has been especially troublesome.  We've generated four release candidates since October.
>> Regards,
>> Trevor
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew DeMerchant
>> Sent: March 19, 2011 7:16 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] MapGuide Open Source 2.2 Release Candidate 4 released
>> Does this RC fix the IE9 problems? I recall reading something on the list that someone had posted about how Mapguide pretty much doesn't work with IE9....Since it's out now, MGOS 2.2 really needs to support it fully. Anyway, just wonrdering! I haven't had a chance to test it out myself quite yet...
>> Andrew
>> On 18/03/2011 10:06 PM, Zac Spitzer wrote:
>>> Just to Clarify,
>>> If you find a defect, please only report it using trac, AFTER first
>>> posting to the mailing list and having the issue confirmed
>>> Regards
>>> Zac
>>> On Sat, Mar 19, 2011 at 4:41 AM, Trevor Wekel
>>>> We are pleased to announce that the MapGuide Open Source project team has made MapGuide Open Source 2.2 Release Candidate 4 available.
>>>> Release notes:
>>>> http://trac.osgeo.org/mapguide/wiki/Release/2.2RC4/Notes
>>>> Downloads:
>>>> http://trac.osgeo.org/mapguide/wiki/Release/2.2RC4/Notes#Installation
>>>> Documentation: Please continue to use the 2.0 documentation for now. The release notes contain information on API changes between MapGuide 2.1 and MapGuide 2.2.
>>>> If you find a defect, please report it using trac.
>>>> Thanks to the ever growing team of developers who are contributing to make the MapGuide Open Source project a more self-sustaining project.
>>>> Regards,
>>>> The MapGuide PSC
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited.  Disclosure to anyone other than the intended recipient does not constitute waiver of privilege.  If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris  les pièces jointes) est confidentiel et peut être privilégié.  La distribution ou la divulgation non autorisée de ce courriel est interdite.  Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège.  Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
