[mapguide-users] MGOS 2.2 RC4 64bit - problem with references
Greg gbneff at cid.utah.gov
Mon Mar 21 14:17:47 EDT 2011
I am trying to modify a .net mapguide web application using:
MGOS 2.2 RC4 64bit
visual studio 2010
windows 7 64 bit
iis 7.5
I receive the following warning in visual studio: ASP.NET runtime error:
Could not load file or assembly 'OSGEO.MapGuide.Foundation' or one of its
dependencies.  An attempt was made to load a program with an incorrect
format.
and when open my web page I get:
The type initializer for 'OSGEO.Mapguide.MapguideApiPINVOKE' threw and
exception.
I have read the following post and followed its suggestions with no luck:
http://osgeo-org.1803224.n2.nabble.com/Compile-Error-An-attempt-was-made-to-load-a-program-with-an-incorrect-format-td6153978.html
This application was working great on another windows 7 64 bit machine but
using MGOS 2.2 Beta 32bit.
I have copied the following 64 bit dlls to my application bin directory and
added references to the same:
OSGeo.Mapguide.Foundation.dll
OSGeo.Mapguide.Geometry.dll
OSGeo.Mapguide.MapguideCommon.dll
OSGeo.Mapguide.PlatformBase.dll
OSGeo.Mapguide.Web.dll
corflags for all shows:
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC>corflags.exe
"C:\Program
Files\OSGeo\MapGuide\Web\www\Cid_Map\bin\OSGeo.MapGuide.Foundation.dll"
Microsoft (R) .NET Framework CorFlags Conversion Tool.  Version  4.0.30319.1
Copyright (c) Microsoft Corporation.  All rights reserved.
Version   : v2.0.50727
CLR Header: 2.5
PE        : PE32+
CorFlags  : 1
ILONLY    : 1
32BIT     : 0
Signed    : 0
Target framework is .net 2.0
Build Platform is Any CPU
MapGuideApplicationPool (of which my application is a member) Enable 32-Bit
Applications is False and .NET Framework Version is v2.0
Is anyone using this type of configuration?  Am I missing  something?  Would
I be better to use the 32 bit version of Mapguide?
Thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGOS-2-2-RC4-64bit-problem-with-references-tp6193359p6193359.html
