[mapguide-users] MapGuide Maestro 3.0 beta 2 now available
    Thomas Lorenzon
    thomas.lorenzon at gmail.com
    Tue Mar 22 13:15:27 EDT 2011
Hi Jack, download doesn't start... Neither .exe nor .zip..
Is there any mirror site?
Thanks, Thomas
2011/3/22 Jackie Ng <jumpinjackie at gmail.com>
> Hi All,
> I am happy to announce the 2nd beta release of MapGuide Maestro 3.0 is now
> available for download:
> NSIS installer:
> http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-Release-3.0b2-Setup.exe
> Zip package:
> http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-3.0b2-Release.zip
> Remember is that this is a beta release. This release should be used for
> testing purposes and feedback. Use for production purposes at your own
> risk.
> Also with this release I would like to start inviting interested parties to
> begin offering translations for this version of Maestro. The translation
> system is the same as previous versions, however given that this version is
> mostly rewritten from scratch, most of the existing translations are no
> longer applicable. So for this release, I've reset the list of translation
> contributors. Your name will be added/re-listed on the credits if you
> provide a translation for this version of Maestro.
> If you need a refresher course in translating Maestro, the link is here:
> http://trac.osgeo.org/mapguide/wiki/maestro/Translation
> Some of the new stuff (from beta 1):
>  - Implemented specialized WMS feature source editor
>  - Added missing connection testing functionality for file-based feature
> source editors
> Beta 2 also has a boatload of fixes for various defects discovered in beta
> 1
> and earlier test builds.
> Once again, some general notes when testing this build:
>  - Found a bug? Ask yourself: Did this bug exist in Maestro 2.x, and hence
> is a known problem?
>  - Similarly, that Maestro 2.x issue you filed in Trac some time ago: Has
> it
> been fixed or successfully worked around with this release?
>  - So generally speaking, it really helps to have an existing installation
> of Maestro 2.x on hand (current release being 2.1.4) as a baseline
> comparison to whether something has been fixed or broken.
>  - Filed an issue under the previous test build or beta? Did this release
> fix this issue for you?
>  - All existing Maestro tickets will be re-targeted to the maestro-3.0
> milestone
>  - Something breaks when running in Mono? It helps to specify the expected
> behaviour when running in Windows. Screenshots help as well. Also indicate
> the version of Mono
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/MapGuide-Maestro-3-0-beta-2-now-available-tp6195931p6195931.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110322/e132d89e/attachment.html
